leaking th400 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2006, 03:58 PM
zephyrc's Avatar
leaking th400
i have a th400 that is fitted with a trans brake { tci}. it has a leak coming from around the bellhousing of the box, it will only leak after accelerating hard,, at the end of the strip it has puked enough fluid to catch fire on the header.the fluid is not coming out of the vent on top of the box, i have a catch can for that.. it seems to come out around the front right hand side,, i have been chasing this problem since early last year,,, any help and advice would be appreciated.. george
Old 05-20-2006, 05:35 PM
Jmark's Avatar
dried out 0-ring on the dip stick tube? Cracked dipstick. Fluid pushed up the dip stick tube? Loose cooler line, cracked cooler line. All of those are on the RF of the trans.
Old 05-21-2006, 02:46 AM
zephyrc's Avatar
thanks jmark i will check these parts today.. george
Old 05-21-2006, 10:22 AM
zephyrc's Avatar
cooler lines are both perished, does the pressure in these lines rise under hard acceleration, i ask because neither leaked when the car was idling , but when i used the air line both were porous at the junction with the box...
HELP QUICK Electric Fuel Pump Leaking 66 T-Bird Engine 4 06-06-2005 06:26 AM
th350 leaking only under load justspeed Transmission - Rearend 10 10-06-2004 09:03 PM
TH400 power handling and RPM range Philly Single Transmission - Rearend 3 09-28-2003 04:51 PM
th400 leaking fluid v8s10 Transmission - Rearend 4 03-16-2003 12:57 PM
TH400 in firebird v/s TH400 in bonniville help speedfrk3 Transmission - Rearend 11 11-04-2002 11:19 AM
