leaking turbo 350 transmission when it sits - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2011, 09:52 AM
When my turbo 350 transmission sits for a few days i find a puddle of fluid on the ground. Lines are tight bottom of pan gets wet. Cleaned it off but can't seem to locate the problem.
Old 04-05-2011, 10:22 AM
Usually it is the shift lever seals leaking ...
It is a very simple job to remove the seal and replace. There is a tool designed just for that purpose.
It is KD 2393 and costs about 10/12 dollars at most any decent REAL parts store. I am guessing on the price. I paid 3 or 4 dollars for mine in the early 70's.
This is more of a transmission question ... so as a MODERATOR ... I am going to move this thread to the transmission area where the MODERATOR there ( Crosley ) can possibly be of more assistance.
DEUCE ... MODERATOR
Old 04-05-2011, 10:48 AM
SSedan64's Avatar
When the Engine's running the fluid level is even with the Pan mounting surface. When the the vehicle sets the Torque Converter will drain back into the Pan and the fluid level rises to where the Dipstick, Detent Cable & Shift Shaft/Lever seals can leak, also the Speedo Cable, Governor and Front & Rear seals. The seals get hard/brittle over time.
There're 2 types of Dipstick & Detent seals, O-ring or Boot style, looks like an upside down Top Hat.
Leaking Turbo 350 renfroe453 Transmission - Rearend 14 03-04-2009 10:46 AM
leaking turbo 350 fast 79 malibu Transmission - Rearend 2 06-09-2008 09:33 AM
Turbo 400 Leaking from vent mauserbull Transmission - Rearend 4 03-18-2006 07:40 PM
Turbo Oil Leaking acliffdweller Engine 6 06-23-2003 09:47 PM
Turbo 350 Transmission Leaking 63 vette Transmission - Rearend 2 02-19-2003 05:02 PM
