-   -   leaking valve cover gasket (http://www.hotrodders.com/forum/leaking-valve-cover-gasket-227205.html)
wingman_g 12-15-2012 01:15 PM
I hAVE A 1940 CHEVY WITH A 350 CHEVY ENGINE,THE ENGINE HAS ALUMINUM VALVE COVERS ON HER. I NOTICED THE COVERS WERE LEAKING OIL SO I TOOK THE COVERS OFF CLEAN THEM AND PUT TWO NEW STEEL CORE RUBBER GASKETS ON. THE PROBLEM STILL EXISTS,LEAKING OIL ONTO THE EXHAUST MANIFOLD CAUSING THEM TO SMOKE, MAYBE I SHOULD CHANGE THEM TO CORK? :welcome: DAVE
69 widetrack 12-15-2012 01:20 PM
If you tightened them down properly, you may have a warp in the Valve cover, put a straight edge on the gasket face to see if they are straight, if they are then I would check torque specs.
Ray
mitmaks 12-15-2012 02:49 PM
might want to put some rtv sealant
