Leaky C4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-23-2002, 06:58 AM
Red face Leaky C4
Ok I am about ready to take a hammer to this thing! I have a 70's C4 and I replaced two round rubber seals. One is on the downshift rod, the other is much larger and fits around the part that shifts the gears with the column shifter (don't know what it is called). That slowed down the leak but this thing still leaves a puddle under the car and all over the starter neutral switch. It seems worse after the car has been running. I'm wondering if there's some kinda trick I am missing ????? ps- I've also replaced the pan gasket.
thanks
keith 63 futura in little rock
Old 12-23-2002, 07:55 AM
aka Duke of URL
Post
I would put the car up on jack stands...wash the case off well with metal/brake cleaner...remove the safety switch and let it idle in gear. It may be that the selector shaft seal was damaged during installation or the bore is damaged.
You also have the intermediate band adjustment right before it and the locknut is actually the seal. Is it leaking and blowing back? Intermediate servo cover leaking?
Worst case scenario...front seal or convertor drain plug leaking and blowing back.
