Leaky C4 pan gasket - AGAIN - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 02-05-2007, 04:05 PM
Irelands child's Avatar
Originally Posted by slowpoke
All that time and money for a little oring.
That was the first place I looked - I have a 1st generation Lokar flex fill tube that has only a single o-ring (new ones have 2) but had siliconed the heck out of it when it was installed. It's totally dry there (so far).
I did a real close inspection of the gasket when I removed the pan - no gasket compression to speak of in that suspect spot but the rest was squashed as expected.
Dave
Irelands child
  #32 (permalink)
Old 02-05-2007, 06:20 PM
russlaferrera
Last wiki edit: Threading tips
Wiki Edits: 2
c4 pan gasket leaking again
As a suggestion, use silicone on the pan place the gasket on and then invert the assy. on a piece of waxed paper, until the silicone cures. Then install. All the voids will be filled and none of the silicone will get forced out...russ
  #33 (permalink)
Old 02-07-2007, 03:54 PM
The new pan is here - and will be bolted on tomorrow. I'll use SS bolts rather then the Home Depot made-in-China junk they supplied. The pan was actually Made in USA tho .
There is plenty of flange area on this one to seal well -
Dave
ID:	18303   Click image for larger version
Irelands child
  #34 (permalink)
Old 02-07-2007, 06:53 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I would be careful not using a gasket on the pan in some applications.. A paper type gasket is better, Duraprene was a name on some gaskets.
As an example : the 700/4L60 trans has a small hole in the pan rail at the 2-4 servo area. IF the hole is plugged by the pan (no gasket) & silicone , this will cause some problems with the 2-4 servo
  #35 (permalink)
Old 02-08-2007, 06:03 AM
This is not a problem with a C4 - it is a flange only. The gasket that came with my new pan is a folded paper piece and will be put aside for emergency use. A non folded Fel-Pro gasket will be used with a thin coat of sealer.
Irelands child
  #36 (permalink)
Old 02-13-2007, 09:21 AM
The new TFS aluminum pan DOES NOT leak - (at least not yet). Nice thick rails, only 10 lb ft of torque on the bolts. So - I can hope that this problem has disappeared .
Dave
Irelands child
New pan gasket without raising engine? rapsag Engine 14 04-21-2006 02:49 PM
Changing pan gasket on 350 chevy rapsag Engine 16 08-04-2005 07:55 AM
Pan Gasket MI2600 Engine 1 05-07-2005 08:45 AM
Oil Pan Gasket Chevy21 Engine 5 03-02-2005 09:15 PM
New Cam Install - Oil pan gasket info requested. Siggy_Freud Engine 5 12-17-2004 11:00 PM
