Still looking for some help with a rebuild kit. I pulled the valve out tonight and figured out why it is leaking. Here is a pic of the valve.
The rubber hat is what's leaking. There is a shoulder on it that slips down into the assembly. The joint from the "hat" to the "shoulder" is ripped. Not a good pic but you can see brass when I pull the hat up.
No reason I know of not to mess with it. It's just the metering valve seal that's bad. The rest of the Proportioning valve is fine. I see no reason to spend 70 to a 100 dollars on the entire valve when all that is needed is a 0.50 cent seal. IF I can find one... That's the issue and probably why no one offers the seals in rebuild kits. Much better to make 80 bucks on the whole assembly then .50 cents on a seal.
I did find a source for a replacement metering valve. CPP carries them from what I am finding. I have an email out to them so we'll see what they have.
Mark
Because we live in a highly litigious society , nobody wants the possible problems that could arise from a failure of a safety related part that's been "tampered " with...
dave
Most of the GM factory combo valves only use o-ring seals, so you can get those anywhere. I've never seen the cup style seal in a GM combo valve. If you have an aftermarket valve, all bets are off.
Astroracer hit the nail on the head. Why sell a $0.50 seal when you can make $80 profit on a complete valve assembly?
Yes, you right about that. I'll keep digging though. I don't have a problem fixing it myself if I can find the right components. If not I will have to open the wallet for a complete valve and just swap out the metering portion...
I looked at Muscle Car Research last weekend. They don't list a rebuild kit for the 71-77 GM Intermediate size car PV71 Metering Valve, which is what I have.
I found brand new complete Metering Valves at CPP though. http://www.classicperform.com/Store2/universal-products.htm
Pt. No. PVMVKT for 10 bucks. About a 1/4 of the way down the page and listed as "PROP METERING VALVE". I won't have to take the old one apart to replace the seals. Just stick the new one in and put the brass plug back in.
I ordered two just incase.
Mark
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
