Leaky Rear Pinion Seal - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2011, 11:08 PM
Pennsy86monteSSGuy's Avatar
Another Old Gear Head
The rear pinion seal on my non-posi 3.73 86 Monte Carlo SS rear end is leaking. I have never replaced one of these, how does one go about doing it? What's the torque spec on re-assembly?
Thanks!
Old 05-02-2011, 09:15 AM
Scandinavian's Avatar
http://www.backfalt.fi/indexse
Last journal entry: Torque Converter
Just as much as the old crush plate was crunshed! it will leak if u dont use gasket glue.
Old 05-04-2011, 05:05 AM
You need to be carefull when doing this job because you may have collapesed the crush sleeve that would make the pinion cocked sideways causing the leak. This is best left to a pro or somebody who's had experience with setting up rearends as the crush sleeve provides preload on the pinion bearings.
Pinion seal on 8.2 10 bolt rear end leaking, replaced still leaking?! artillerystevens Transmission - Rearend 6 04-10-2011 03:57 PM
Need help with 12 bolt rear end pinion seal. cujoe822 Transmission - Rearend 10 09-07-2006 10:47 AM
Corvette 68 Rear End Pinion Seal... Mean@MeanMother Transmission - Rearend 5 06-08-2006 10:07 PM
Corvette 68 Rear End Pinion Seal... Mean@MeanMother Transmission - Rearend 0 06-06-2006 05:26 PM
Replacing Rear Diff Pinion Seal...question??? Frankoholic78 Transmission - Rearend 13 05-25-2006 06:09 AM
