Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Lean backfire
Thread: Lean backfire
Old 04-15-2003, 05:45 PM
1BAD80's Avatar
1BAD80 1BAD80 is offline
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Post
You say it runs rich until you step on the throttle then goes lean. It sounds like you have 2 condition's. Do you have any holes drilled in the throttle plates (butterflys)?
One is drop the front jets down 2 numbers, and when you hit it the pedel that's when it goes lean ,that's the accelerator pump system. Put on a red pump cam on the #1 hole, and a 3.5 power valve. Sounds like a larger pump nozzle size needed
I Copied from Holly a little to make it easer to understand and write faster.
The accelerator pump system consists of three main components: the pump diaphragm, the pump cam and the pump nozzle. This is the carburetor system that is most responsible for having good, crisp, off-idle throttle response. Its purpose is to inject a certain amount of fuel down the throttle bores when the throttle is opened. By accomplishing this purpose it acts to smooth the transition between the idle and main circuits so that no stumble, hesitation or sluggishness will be evident during this transition phase.
The first adjustment to check is the clearance between the pump operating lever and the pump diaphragm cover's arm, at wide open throttle. This clearance should be around .015". The purpose for this clearance is to assure that the pump diaphragm is never stretched to its maximum limit
at wide open throttle. This will cause premature pump failure. Once this clearance has been set take a good look at the pump linkage and work the throttle. Make sure that the accelerator pump arm is being activated the moment that the throttle begins to move. This will assure that pump response will be instantaneous to the movement of the throttle. These adjustments can be made by turning the accelerator pump adjusting screw that is located on the accelerator pump arm together with the
pump override spring and lock nut.
The amount of fuel that can be delivered by one accelerator pump stroke is determined by the pump's capacity and the profile of the pump cam. The period of time that it will take for this pre-determined amount of fuel to be delivered is affected by the pump nozzle size.
A larger pump nozzle will allow this fuel to be delivered much sooner than a smaller pump nozzle. If you need more pump shot sooner, then a larger pump nozzle size is required. During acceleration tests, if you notice that the car first hesitates and then picks up, it's a sure bet that the pump nozzle size should be increased. A backfire (lean condition) on acceleration also calls for a step up in pump nozzle size. Conversely, if off-idle acceleration does not feel crisp or clean, then the pump nozzle size may already be too large. In this case a smaller size is required.
Holley accelerator pump nozzles are stamped with a number which indicates the drilled pump hole size. For example, a pump nozzle stamped "35" is drilled .035". Pump nozzle sizes are available from .025" to .052". Please note that whenever a .040" or larger accelerator pump nozzle is installed the "hollow" pump nozzle screw, P/N 26-12, should also be used. This screw will allow more fuel to flow to the pump nozzle, assuring that the pump nozzle itself will be the limiting restriction in the accelerator pump fuel supply system.
NOTE: When changing the pump nozzle it's best to jump three sizes. For
example if there's currently a off-line hesitation with #28 (.028")
pump nozzle, try a #31(.031") pump nozzle. If you must use a #37 (.037")
or larger pump nozzle, then also use a 50cc pump. The same applies to the accelerator pump cams. Once a pump nozzle size selection has been made the accelerator pump system can be further
tailored with the pump cam. Holley offers an assortment of different pump cams, each with uniquely different lift and duration profiles, that are available under Holley P/N 20-12. Switching cams will directly affect the movement of the accelerator pump lever and, subsequently, the amount of fuel available at the pump nozzle. Lay out the pump cams side by side and note the profile differences. This little exercise may help to better explain the differences between the cams and their effect on pump action.
If you still need any help please email me. IM getting some annular boosters to put on my 2 650 carbs on my cross ram to make it twice of responcive, 9 holes compaired to 3 in a regular one. Getting themfromCNCMotorsports <a href="http://www.cnc-motorsports.com/default.asp" target="_blank">http://www.cnc-motorsports.com/default.asp</a> a good place for rebuild kits and other parts.
<img src="graemlins/sweat.gif" border="0" alt="[sweat]" />
[ April 15, 2003: Message edited by: 1BAD80 ]</p>
Luv the smell of NITRO in the morning.
