Lean Burn Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2003, 08:05 AM
Post Lean Burn Help
I was wondering if anyone would be able to help me. I have a 1988 Pylmouth Gran Fury with 318 2 barrel. I'm suspecting the Lean Burn isn't working properly. It has a stumble whenever you touch the gas. The oxygen sensor has been replaced as with the distributor cap and rotor. Anything would be nice. Thanks so much!
Old 01-30-2003, 08:16 AM
Post
Took the Electronic Lean Burn system out of my 77 Newport, and replaced it with an electronic ignition system. Probably the best advice I could give you, had no problems since.
Old 01-30-2003, 04:28 PM
WoodsEdge's Avatar
Post
I also have the lean burn and plan on replacing it. I don't think Chrysler even understood the lean burn system.
Jack
Old 01-31-2003, 04:58 AM
Post
Is it hard to get rid of the Lean Burn system? How expensive is it? I'm wanting to get it off so bad. Thanks for your help!
Old 01-31-2003, 05:13 AM
aka Duke of URL
Question
It has been quite awhile since I worked on a lean burn, but doesn't an '88 have an ECM, whereas the '77 had the control unit mounted on the air cleaner asm.?
I think we may have two different systems here.
Old 02-01-2003, 03:28 PM
Post
Its attached top air cleaner with a bunch of wires running off of it. Is there a way to override it? Thanks alot!
Old 02-01-2003, 03:30 PM
Post
CORRECTION: The Lean Burn main control box is attached to the drivers side of the air cleaner.
Old 02-03-2003, 05:24 PM
New Member
Cool
I have de lean burned a 400 out of a 1977 Newport but it went into an electronic equipped vehicle, making it easier... As I see it you will need a new distributor (one with only two wires coming out), the old coil should work fine, then you'll need a new ecu and possibly a voltage regulator/ ballast resistor. I'm not 100% sure about the ignition switch in the car but I'm sure you'll be able to gear it up to work without too much trouble. You'll need to find a wiring diagram of a dodge electronic car.
A few .000's, ( around .023 is my preference) off the heads and a new cam does wonders for those smog engines
Old 02-03-2003, 07:31 PM
4 Jaw Chuck's Avatar
Post
Direct Connection used to sell a kit to get rid of the lean burn system, try your local Dodge/Chrysler dealer catalogue. I seem to remember it consisted of a new distributor and ignition module with the correct connectors to fit without cutting.
Outlawed tunes from outlawed pipes
Old 02-04-2003, 07:57 AM
2-manytoyzs's Avatar
Start those projects someday
Last journal entry: Divco - has been on the back burner
Post
Found this site after reading your post. Now you got me interested in solving my driveability problem w/ my Ramcharger. web page
Any other chrysler guys out there with a fix for these???
