Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - lean mixture?
Thread: lean mixture?
Old 01-19-2013, 04:57 PM
jeepers creepers jeepers creepers is offline
Originally Posted by 64nailhead View Post
I'm not familiar with a 'Howell EFI' system, but I would find it hard to believe that it wasn't designed to be used with either a narrow or wide band 02 sensor (A/F meter same as AirFuelRatio gauge.) I recommend an Innovate LC1, but there are others are out there that work also.
EFI without AFR gauge is like marriage without sex - what's the point -
Can you datalog with the Howell system?
The TBI kit comes with the oxygen sensor so it should manage the air/fuel mixture a little.
