Originally Posted by jeepers creepers
Plugs look all like that, they have a white spot on electrode and ceramic surrounded by a dark layer down below.
What do you think about them? Mixture is ok but too hot plugs?
Any help will be greatly appreciated.
New plugs needed, it's all but impossible to read a plug that is old or has been idled after a WOT run. Your plugs were hot at some point, though. Besides the other suggestions, be sure the heat range isn't too hot. Be sure the timing is all in at or before 3000 rpm and that the
timing advance curve is set up correctly.
Reading plugs
