Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - lean mixture?
Thread: lean mixture?
  #25 (permalink)
Old 01-22-2013, 08:04 PM
cdminter59 cdminter59 is offline
lean mixture?
Originally Posted by jeepers creepers View Post
today i replaced three spark plug caps, one of them was cracked quite a bit, fixed a wire, gapped the spark plugs to .035, advanced an hair the timing and problem still, motor now has a superfast throttle response, no knocking or detonating, a friend of mine borrowed my timing light so i'll check it tomorrow, i know there are tons of variables but what' s the common total timing for the 350? are 35 degrees ok?
I want to measure the o2 sensor voltage as well, hope to do that tomorrow.
Try about 10-12 initial timing, and the total timing of 36* all in by 3000 rpms. You might have to get an advance curve kit for the distributor. Here is another article on tuning your HEI and setting your timing. http://www.crankshaftcoalition.com/w...EI_distributor
