Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - lean mixture?
Thread: lean mixture?
  #34 (permalink)
Old 01-25-2013, 04:38 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by jeepers creepers View Post
i printed out the article yesterday night! thank you.
I checked timing again and did some work on it, by setting the initial advance to 10-12 degrees i get a total of 44 with bith mechanical and vacuum,i thought was too much so i tried to disconnect the vacuum one...result is that mechanical only advances 16-18 degrees so i'm reaching 30ish at 4000 RPM wich is too much.
Reading the article on cranckshaft coalition, they say advance can go up to 45-50 during light throttle cruise with no problem getting a better fuel mileage and a cooler engine, i'm not considering mileage like the goal, i just want to solve this problem and a healthy engine, fuel mileage is a bonus.
I' ve got new spark plugs 10 minutes ago, they're colder than the previous Accel, i hope will help.
Another thing i noticed driving the car is the misfiring happens just if i push down the pedal all the way suddenly but not if i rev up the engine gently, guessing is a good clue for you, i'm thinking about too much fuel and a denser mixture in the combustion chamber coupled with a too hot plug that cause preignition?
Just wondering...
I'd give it 16-18 degrees of initial and use a vacuum advance limited to 10 degrees, or use the vacuum advance you have now and if you're getting too much timing at idle w/it hooked to manifold vacuum, just hook it to ported vacuum.
Use a lighter spring on one side to see if you can get the timing all in by about 3000 rpm.
