Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - lean mixture?
Thread: lean mixture?
  #35 (permalink)
Old 01-25-2013, 08:11 AM
jeepers creepers jeepers creepers is offline
Originally Posted by cobalt327 View Post
I'd give it 16-18 degrees of initial and use a vacuum advance limited to 10 degrees, or use the vacuum advance you have now and if you're getting too much timing at idle w/it hooked to manifold vacuum, just hook it to ported vacuum.
Use a lighter spring on one side to see if you can get the timing all in by about 3000 rpm.
Thank you Cobalt, i already put a lighter spring on one side and the curve is ok but i have definately good news...
Did you know that i'm an idiot? I checked today the lenght of the spark plugs hole in the cylinder heads (Edelbrock alu) and it's about double compared to the stock cast iron so the plugs i put on before were reaching just half of that!!!
poor engine...i just put the new NGK BRP6EFS plugs on and i will try them very soon, can't wait to...
