Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Lean problems with BG Speed Demon carb
Old 04-04-2008, 12:39 PM
Sixtyninemercury Sixtyninemercury is offline
Originally Posted by Boosted89RS
are u using a wideband afr gauge or a narrow band gauge also is it a heated o2 if its a narrow band.
reason i ask is if its a narrow band o2 they are only accurate around 14.7 afr at 15.5 afr the thing can read dead lean, same goes for the opposite direction.
also if ur using a narrow band and its a non heated type at idle the sensor may be droping below operating temp witch will also cause a lean reading.
if u are using a single wire o2 sensor i suggest going to a 3 or 4 wire heated o2 both are the same the only diff between the 2 is the 4 wire has its own ground wire so it dosent rely on getting ground from being screwed into the ex system
also narrow bands should not be relied apon to much for anything other then wot
Yes mine is heated. This motor has had many carbs on it - Edelbrock and Holley - and this is the first time I've ever had this crazy experience on my A/F meter. I am experienced enough to tell how it drives after it warms up and the meter is just confirming what I am feeling through the gas pedal.
It is not the meter!
