Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Lean or rich
Thread: Lean or rich
Old 06-10-2003, 09:05 PM
TurboS10's Avatar
TurboS10 TurboS10 is offline
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
If you are going to run an AF meter, then you need to look into a good one. The $30 ebay jobs are, as stated earlier, worthless. I think an Auto Meter will run around $100-150 and you are still seeing what the ratio was. I would say that this is not all together worthless. It can give you a good idea of what is happening at wide open throttle. It is not perfect though.
Chris
