Lean or rich - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-08-2003, 05:00 PM
72elcamino's Avatar
Post Lean or rich
Im going through the process of tuning my carb and I purchased one of the Edlebrock air/fuel meters with the weld in oxygen sensor. I've been working on this for a few days and think everything looks good at least according to the O2 sensor. I just pulled the plugs and thier white as can be. I can't understand how the O2 sensor can give one reading and the plugs another. The O2 sensor is installed exactly where the directions say. I need to emmission the car by the end of the month and don't think it's gonna pass. Any help would be appreciated.
Old 06-08-2003, 05:14 PM
Post
I live in Florida and the emission test were stoped a few years ago, but you can get almost any pre 1980 car passed by seting the timing on 0 and lean the mixtute down if your are border line change the oil or unplug the P.C.V. valve. Good Luck. JF
Old 06-10-2003, 08:20 AM
lozinit's Avatar
Resident Evil Penguin Wrangler
A/F ratio gauges are fairly worthless IMO, unless you are running a wideband O2 sensor. Wideband O2's are fairly expensive and rather delicate, so it doesn't make much sense to install one of these.
The gauge will NEVER give you a real time view of your stoich, but instead will display a latent "trend" of how your mixture is.
Like I said though, do not rely on the gauge to give an accurate description of your air/fuel. I have one installed on my t-bird, and when I first got it, I thought it was something I HAD to have to make sure I wasn't going lean. Now, it's nothing more than a pretty LED that sweeps from side to side. Dashboard decoration.
Believe what your plugs tell you and not what the gauge tells you.
~Michael
Old 06-10-2003, 08:19 PM
4 Jaw Chuck's Avatar
The evil penguin wrangler knows of what he speaks.:laugh:
— Han Solo
Old 06-10-2003, 09:05 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
If you are going to run an AF meter, then you need to look into a good one. The $30 ebay jobs are, as stated earlier, worthless. I think an Auto Meter will run around $100-150 and you are still seeing what the ratio was. I would say that this is not all together worthless. It can give you a good idea of what is happening at wide open throttle. It is not perfect though.
Chris
Old 06-10-2003, 09:50 PM
72elcamino's Avatar
Thanks for the help guys.
