Learn to race - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2004, 03:06 PM
Cruiseomatic's Avatar
Heart Breaker and Life Taker
Learn to race
Well,it finally happened. I got challenged to race. an '89 f-150 vs. a '92 bronco.
How do i race him? ivew never done it before. so im a little scarred. i told him,im goin to the track only,no street.he said ok. but do i put the tranny in neutral,hold the brake,and then bring the shifter to drive,but not let go. when the light changes,let the shifter go and punch it or what?
Thanks.
Old 07-25-2004, 03:13 PM
badknuckles's Avatar
you talkin to me?
just make sure you powerbrake at the line
Old 07-25-2004, 03:16 PM
what i was gona do is this,
pull up to the line,put the foot brake on,take it out of drive and into neutral,let the shifter go so it goes out of gear,then take it back into drive but hold the shifter,so it doesnt go into gear,when the light changes,let the brake go and the shifter at the same time and punch her. aww hell,im gonna probably lose anyway. but its worth a shot.
Old 07-25-2004, 03:55 PM
Tazz
about to race
Pull up to the per-stage light and roll your front tire into the staging light, holding down the brake press your lign-lock and press the gas pedal but don't roll your car till the last yellow light light's up then let off the line lock button and mash the gas to the floor and you cut a good light and maybe win!!
Tazz
Rat Rodz Rule!
Old 07-25-2004, 04:17 PM
Meka's Avatar
What kind of engines do both vehicles have in them?
Old 07-25-2004, 04:59 PM
coldknock's Avatar
Like tazz said.
Creep up till you turn on the second stage light.
Let go of the brake and roll into the accelerator at the same time. Don't stomp it and spin the tire off.
Don't wait for the light to turn green to do this, you'll lose. Go when the last amber light comes on. By the time you react and the truck starts moving, the green light will be on.
Good luck.
Larry
Old 07-25-2004, 05:24 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
You guys should be ok racing on the street, neither of your trucks will be able to get above the speed limit by the time you get to the next light anyway.-- j/k
Leave it Drive with your foot on the brake, when the third amber light comes on GO. When you've gone far enough down the track to have completed a 1/4 mile you should see a white line painted on the track, thats means your done, start stopping.
Larry I think he'll be ok stomping it, it's only got an I6.
Hey guys how can we call ourselves hotrodders if we don't give him any advise on how to give himself the edge when he's going down the 1/4?
Cruise to make that truck run a little faster take the extra weight out, spare tire, jack, hub caps, anything you can easy take off. Leave the tailgate down or take it off, take off the air cleaner assembly, and pump the front tires up to the max recommended psi (cut rolling resistance). Thats all I can think of right now.
Old 07-25-2004, 05:53 PM
Nightfire's Avatar
Young & Idealistic
Last journal entry: 1950 Fargo - losing hope
Wiki Edits: 4
Call me stupid but can't he just have it in "drive" with the foot on the brake and when light hits green roll onto the gas?
Like Ghetto suggested, take the air cleaner assembly off, mix some alcohol into your fuel and take the exhaust off for a bit more power.
I know it's only for ONE race but it's for THE race right?
Mike
Old 07-25-2004, 06:33 PM
coldknock's Avatar
My old '65 would light 'em up real well. 300" I6
Cruise,
A couple of practice runs wouldn't hurt. Try it both ways and look at the 60' times. Sometimes coming off idle will make the converter flash a little higher, if it is an automatic.
If leaving off idle, you can try deep staging. Roll into the lights just enough to make the top staging light go out. It'll shorten the R/T if it's a bit on the high side and make the other dude get nervous. He might think you know something he doesn't.
Oh, I almost forgot. When your left leg starts jumpimg up and down, just push a little harder on the pedal. You'll see what I'm talking about when you get into the lights.
Larry
Old 07-25-2004, 06:51 PM
Ghetto Jet's Avatar
We used to have an 82 F-150 with a 300/C6, open rear, it ran great but wouldn't turn a tire from a dead stop.
Old 07-25-2004, 07:07 PM
coldknock's Avatar
I have to admit I did have the block zero decked. Oh and the head was milled 0.060" or so. I think the cam might have been from Comp. Oh yeah it had a Clifford header on it.
Ok I cheated. He'll still whip the Bronco, I have faith and he has instructions.
Larry
Old 07-25-2004, 07:16 PM
Last journal entry: Misc.
Hey cruise, here is what I always do. Ok, leave it in drive, hold down the brake as hard as you can with your left foot, then with your right foot press the gas as much as you can without "Peeling Out" and as soon as the third yellow light hits when you're all ready, let go of the brake and finish off the gas to the floor and hope to god you win. Does he have a 302ci or a 351ci? Is his stock?
Old 07-25-2004, 10:08 PM
just got back home,he told me he was gonna race his car. which is the bronco,he didnt tell my *** he bought a '66 mustang. thats what he wants to race. it sounds good,it has a v8. i think ive got an idea how to start it off from the line. but whats the line-lock? and what does it do?
Old 07-25-2004, 10:14 PM
Dont do it the mustang will smoke your truck its a lot lighter.
Old 07-25-2004, 10:16 PM
I noticed that post earlier. A line lock is a button you can hold down after you pump your brakes 3-5 times and hold the button, it'll keep your front brakes on so you can floor it without moving really, kinda like powerbraking except better for your brakes. You don't have one on your truck, nothing comes with it, you buy it aftermarket. Or, if you want to go a step further with automatics, you can buy a trans brake which will keep the car at a dead stop and you can rev it up as high as you want while the button is down and when you let go it's exactly like popping the clutch.
