learning to weld, any tips or advice - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-25-2008, 12:24 PM
OHD's Avatar
OHD OHD is offline
JC are great also the HS adult education places have programs.
In this area the lead/head welding inspector at US restoration facility teaches a class and brings in real titanium, magnesium, SS and other high end materials to practice on...CHEAP.....
  #17 (permalink)
Old 10-25-2008, 01:33 PM
powerrodsmike's Avatar
Wiki Edits: 161
All of the above suggestions are excellent. I will add one more peice of advice that has helped me throughout the last 32 years since I took my first metalshop class. It was standard practice in class to test your welds.
Weld on scrap steel of similar thickness and joint design to the welds that you are going to be constructing your part out of, then test it to destruction. This is part of the same procedure that will be used for the various AWS welders certifications that a guy must obtain to be employed at any number of fabrication jobs.
Here are some pics of some TIG welds that I made when I had practiced enough to actually start to use. I used the same steel and joint design as I was going to construct my part from, tried a couple of different weave patterns, then put it in my 55 ton shop press to try to break it...
As you can see, the part remained intact, distorting the weld as if it was a single peice of steel. The angle those parts were welded together on was twice what you see there. The round depression is from the press ram.
It took 11 tons to bend and distort that peice of steel like that.
Here is the part I was building..Shockwave crossmember for a 68 Imperial with a 9" ford and 4 bar setup.
You should also make welds on scrap, cut the sample apart at right angles to the weld, then use some of the spot check materials commercially available to check for voids or no penetration at the weld bead to base metal. You can also get friendly with the local machine shop, and have the part magnafluxed.
You can also weld your samples, then put them in a vise, and beat the part apart, or bend the part right at the weld...If the weld breaks, you have not succeeded in welding it.
I hadn't stick welded in years, so when I wanted to use my stick feature on my TIG, I did some sample parts..
Welded one edge in a T joint on 1/4" mild steel.
Start bend.
Point of failure.
As the steel had bent considerably past it's yield point prior to failure just past the weld, I considered this weld a success.
Every new joint design goes through the same process at my shop. Especially if it a production part, several samples of the actual part get tested.
I sleep well at night, I do not worry about my welds at all.
One more thing....practice..practice and more practice.
There is no substitute for seat time.
Later, mikey
ID:	33519   Click image for larger version
ID:	33520   Click image for larger version
ID:	33521   Click image for larger version
BE different....ACT normal.
  #18 (permalink)
Old 10-25-2008, 04:16 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
i just took delivery of a new Miller 140 auto-set and it came with a nice CD on setup and trouble shooting. I would reccomend getting that CD from miller as it has a good refresher even if one has been welding for years..
Sam
  #19 (permalink)
Old 12-29-2008, 08:54 PM
72 grabber 51F-1 65 chevystang
We got the welder out yesterday. We put a small spool of wire in it and it worked great. I played around with it today and I can lay down a smooth bead.
  #20 (permalink)
Old 12-30-2008, 01:57 PM
Vegaguy's Avatar
If you underneath the door where the spool is the is a settings chart for heat and wire speed for the thickness of metal you are welding. Start out with those settings for whatever your welding. Their settings are pretty close to get you going. Once you get better youll learn to fine tune the settings. Keep your nozzle around 1/4"-3/8" from your work. Once you get the hang of the MM175 youll love it, I know I have no complaints about mine. Also you can rent welding videos from here Http://smartflix.com/store/category/27/Welding I have rented a few and they are pretty good. Also try your local library for welding books. Good Luck!
Dont forget, practice, practice, practice
  #21 (permalink)
Old 12-30-2008, 02:13 PM
Wiki Edits: 3
one of the things you guys can do is cut some coupons out of the practice parts that you have welded and then put them in the vise and beat on them until they break,,When you can weld pieces that do not break then you are getting there..
Sam
welder reccomendations? rally4x4racer Garage - Tools 32 10-14-2008 10:00 PM
replacement pickup truck - your advice please jojo99 Hotrodding Basics 7 05-03-2006 11:52 PM
replacement pickup truck - your advice please jojo99 Engine 3 04-28-2006 05:48 PM
replacement pickup truck - your advice please jojo99 General Rodding Tech 6 04-28-2006 02:18 PM
Jag Rear End Advice farna Transmission - Rearend 3 06-13-2003 07:52 PM
