Least aggressive method to remove sand scratches - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-10-2009, 05:40 AM
I posted this in the wrong spot (thanks ChevelleSS), but here it is in the right forum:
What's the least aggressive method to remove 2000 grit wet sand scratches? I have a rotary and DA polisher, but was curious what I should use to remove the scratches. Im assuming the rotary with something like Meguiars Diamond Cut 2.0? Do I have to use a wool pad or can I use a foam one?
As you can see, I need some help to get me going in the right polishing direction.
Thanks,
Old 02-10-2009, 06:26 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
use a foam pad and a fine polish compound and see how it works for you..then finish with a hand compound to remove swirl marks..
Sam
Old 02-10-2009, 06:57 AM
What type of foam pad would you recommend? I found about 6 different types at Carquest.
Old 02-10-2009, 08:01 AM
302 Z28's Avatar
If you have an air powered DA you can use the Abralon pads from Mirka.
They are 4000 grit and can be used with water to wind up with a slightly shiny surface that will dramatically speed up your final buffing.
Vince
Old 02-10-2009, 08:25 AM
My DA is just a cheap little 2600rpm speed. My rotary is a variable speed, 800rpm to 3000.
Old 02-10-2009, 08:58 AM
302 Z28's Avatar
You can buy a cheap air powered DA from Harbor Freight, the one I have has been going strong for 10 years. Those pads are designed (I believe) to be used wet, I would caution against doing that with an electric powered DA They do save a huge amount of time and effort to achieve a primo finish
Vince
How to remove hard water stains on paint 63' Falcon Gasser Body - Exterior 4 08-31-2004 11:58 PM
How to remove factory stripes? newchevyman Body - Exterior 2 03-06-2004 09:34 AM
question on how to remove factory stereo from 94 gmc sierra shane7643701 Interior 0 02-28-2004 07:15 AM
Removing Transmission in a 82 grand prix? fox Transmission - Rearend 1 10-09-2003 10:48 PM
