Leaving it in primer - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2011, 04:46 PM
I don't have the luxury of letting my dd sit until I get all the body and metal work done and was wondering instead of rattle canning some primer on every time I get done with a section just to sand it back off again before I start with the real stuff can I just spray my automotive primer on and leave it sit as is until im ready to paint the entire truck, is it porous, will moisture affect the primer, is this a bad idea in general. I dont want to cut any corners I'm not looking for a show finish but dont want it to look like crap either it would just be easier to do one bed side get it into primer do the other side so on and so forth. Thanks guys
Old 05-02-2011, 05:15 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Sending a Pm..
Sam
Old 05-02-2011, 05:21 PM
If you're using epoxy primer, you can spray it and
drive it; no worries about it being waterproof.
If you're using etching primer, then it is somewhat porous,
and driving in rain might cause some rusting underneath.
Rattle can primer won't give much protection, although
there's some 2K epoxy in rattle cans these days....might be
worth a look.
Old 05-02-2011, 07:22 PM
What about 2K filler primer?
Old 05-02-2011, 09:10 PM
if you are considering going the 2k route why not go with epoxy? Check out this thread to answer your question about the 2k filler primer
2k primer on bare metal
Old 05-03-2011, 09:19 AM
302 Z28's Avatar
Not water proof, it needs to be epoxy and even with that the epoxy over time will chalk up.
Vince
Old 05-03-2011, 09:22 AM
Wiki Edits: 3
Epoxy will over time chalk up but having to do a good scuffing sure beats redoing rust though..m
Sa
Old 05-03-2011, 09:37 AM
Coaner, if you're sold on the epoxy primer by now,
but don't want to drag out the spray gun every time
you do body work, how about rolling it on? A small trim
roller works good for covering fresh body work, and you
can mix up only the amount of primer needed at that time.
(With the added benefit of no masking, no suiting up, no
noisy compressor, no gun cleaning, etc., you get the idea.)
Yes, you'll need to block it out a bit, but nothing like
having to sand off the rattle can stuff and starting all over.
The epoxy primer will give a worry-free finish that you can
drive in all kinds of weather, until you're ready to move on....
Old 05-03-2011, 02:35 PM
Thanks for the responses guys the epoxy is on the way i might have to give the rolling on a thought, what grit should i prep the factory paint before putting down the epoxy? and what should grit should i scuff the cured epoxy with before applying the next coat of paint.
leaving filler uncoated.... Hwyhogg Body - Exterior 13 09-13-2010 09:03 PM
I'm Leaving Hotrodders.com ElegantInventor Hotrodders' Lounge 199 09-10-2006 09:16 PM
I'm leaving... Nightfire Hotrodders' Lounge 17 06-30-2006 05:49 AM
Leaving your car at an Upholstery shop?? HotRodMan Interior 7 12-13-2005 07:13 PM
Im leaving Novaman78 Hotrodders' Lounge 3 02-05-2005 07:45 PM
