Leaving protective coating on rotors? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-07-2008, 05:32 PM
cboy's Avatar
Last journal entry: Finished
I'll be installing new rotors tomorrow on the sedan/delivery. I understand that removing the protective coating is normal for a typical install. However, I will not be driving the car until late spring or early summer. Is it advisable to leave the coating on to prevent surface rust and then burn it off with the first few uses of the brakes?
Always learning...and sharing what I've learned.
Old 10-07-2008, 05:38 PM
Wiki Edits: 31
until I was tought to clean them off I never did, and never had a problem.. I still don't clean them if I don't have a can of brake cleaner around.
Old 10-07-2008, 07:23 PM
T-bucket23's Avatar
Wiki Edits: 26
It will wash off with soap and water. Leave it for now but clean it before you drive it. The coating will end up coating the pads and possibly over heating them.
Old 10-08-2008, 06:58 AM
cboy's Avatar
Thanks guys. I'll put them together today with the protection left on.
Difference in rotors? gsrokmix Suspension - Brakes - Steering 8 04-17-2008 05:08 PM
GM rotors with Ford bolt pattern junkyardjeff Suspension - Brakes - Steering 4 01-26-2008 04:24 PM
cross drilled rotors on a 67 chevelle m.docken Suspension - Brakes - Steering 13 02-23-2007 07:26 PM
blank rotors Mr Miyagi Suspension - Brakes - Steering 1 03-13-2005 08:28 PM
Header Clearance Issue/Question About Damaging Ceramic Coating. Ghetto Jet Engine 9 10-09-2004 12:45 PM
