Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - leaving a unibody on jackstands...
Old 01-13-2004, 09:16 PM
poncho62's Avatar
poncho62 poncho62 is offline
Wiki Edits: 5
I was not aware that a Skylark was a unibody. The 64 and up are not.
Anyways, it all depends where you are putting the stands. If you put them under the "A" frames and rear axle, its the same as sitting on the ground. If the stands are toward the middle or toward the ends, I would be leary, especially being a convertible.
