I had the same problem, replaced the flasher with a heavy duty flasher and that fix my problem
well...maybe i should clarify...
i have purchased some but have not recieved them yet... thanx for the info...i guess im in "wait and see" mode for now ![]() i remembered after buying them about the flasher issue so i thought i would ask... thanx all! |
friend of mine had some and had a problem with them flashing. I will recommend the different flasher to him. good luck let us know how they work!! Thx Brian
If your cruise control requires a 'signal' from the brake light circuit, you will probably need the resistor, or, install another incandescent inline with the brake circuit. Or hide a bulb on each side of the car to create the necessary draw to disengage the cruise.
Bryan |
I tried a set ... and did NOT like them ...
I found a #2057 works better for me ... in a older style tail light. |
Another thing to remember, LED's are directional. Once you get about 15 degrees from direct viewpoint, they are less visable than a regular light bulb. just my .02 |
You guys must be getting some really cheap LED lights. The ones I have on my 34 are very bright and the optical reflector lense they are in allows very good viewing from the sides, at least as good as traditional bulbs and lenses.
Vince |
I'm not sure but I don't think this will be an issue with these... |
Where'd you get thos LEDs, okeesignguy?
| Retrofitting LED bulbs? | Jag Daddy | Electrical | 4 | 09-08-2003 04:16 PM |
