Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > General Rodding Tech
  #1
Old 08-15-2005, 10:12 AM
mitmaks's Avatar
mitmaks mitmaks is offline
Lead Additive
anyone using led additive, what are pro's, con's
Ive got stock 906 heads on my 440 so I think theyre not hardened valve seats.
Old 08-16-2005, 11:08 PM
mitmaks's Avatar
re: LED additive
24 views and no replies, cmon guys
Old 08-17-2005, 06:16 PM
matt167 matt167 is offline
 matt167's barnstar
Wiki Edits: 19
re: LED additive
If it makes ya feel better, use it, if the heads have never had a valve job ( non hardened seats, I doubt they are ) there are arleady traces of lead in the seats from running leadded gas in the past so they are getting lubricated by the lead anyway. Really, it's a myth to need it, in normal driving conditions, you don't need it and it's not going to affect anything if you do or don't use it.
Old 08-17-2005, 07:22 PM
mitmaks's Avatar
re: LED additive
ive always read that valves would dig into heads without lead.
Old 08-22-2005, 05:31 PM
 matt167's barnstar
Wiki Edits: 19
re: LED additive
that is all a myth. All the lead does is lubricate the soft valve seats, if the heads have not been rebuilt, there is lead deposits built up in the valve seats, which lubricates them.
Old 08-23-2005, 01:17 AM
Kevin45's Avatar
Kevin45 Kevin45 is offline
Just one of the guys
re: LED additive
If everything is ground properly and the engine is tuned properly you will have years of trouble free driving without tearing up the heads.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "LED additive"
STop/tail Turn LED wiring chrisf Electrical 3 02-10-2005 07:13 PM
Ford 8.8 , Lucas Syn. need Ford additive? Frank K Transmission - Rearend 6 08-16-2004 01:03 PM
z-max additive christopher406 Engine 10 11-01-2003 06:27 PM
Auto Body led Dawger Body - Exterior 3 09-19-2003 11:30 PM
flexibility additive CNY.PT Body - Exterior 3 11-06-2002 01:51 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
