If the flasher works with what you have now it will certainly work if you add LEDs to the mix. If you change the rear lights to LED then you'd have to get a different flasher.
You will need to replace the front parking lights with a double filament type socket and bulb similar to the rear.
You will need a turn signal switch for the steering column. The standard (thermal type) flashers depend on the current draw of the bulbs to work. The LED bulbs don,t provide enough current draw to operate the flasher. Get on designed for use with LEDs. Most of the above parts can be found here: www.speedwaymotors.com See attached wiring diagram. vicrod |
LED Flasher
Thank you Adantessr,
I know about that flasher but I want to mix LEDs with my existing filament lighting. I don't think I can get both working on one type of flasher. I kinda like the small bulb in-line idea ~ but which line do they go in, the hot or the ground? |
Vicrod,
He's going to use the filament bulbs that are existing on the rear, so he wouldn't need an LED flasher if he's only going to add LED lights to the front. Of course he would have to wire the turn signal circuit into the brake light circuit. Correct? |
LED and bulb mix?
I have a question about using filament bulbs in-line with the LEDs as suggested above.
Can I use very small bulbs (to also act as indicator lights on the dash) or would they not have enough resistance? |
You need at least 2 filament type bulbs to cause enough current draw to use a thermal type flasher.
A solid state (LED) flasher does not depend on load to flash at the preset rate. They have an internal timer circuit to determine the flash rate. They will work with any type of lamp up to max ampere rating of the flasher. The front turn signals will be switched (in the column switch) separately from the rear. The rear turn signals are the same filament as the brake lights. See the diagram I sent earlier. Each lamp has a dedicated switch. When you move the handle LEFT two switches close which sends power to the front and rear lamps. Ditto the RIGHT. If you hit the brakes the side that is not signaling will light but the signal will continue to flash. Not sure what you mean by "small bulb in-line idea" but bulbs are not normally wired in series. Turn signal circuits are normally in the positive (hot) side. The dash indicator lights can be wired in parallel with the front turn signal bulbs regardless of type. Small LED bulb packages are readily available to work on 12 volts. vicrod Last edited by vicrod; 09-01-2010 at 01:31 PM. |
Yes you can mix them, I did it on my S10, if you have "hyperflash" or they flash way too fast there is a resistor pack at the auto parts store for $10 it puts the load on the flasher that the LED's wont.
| LED 1157 bulb stems too short. | cboy | Electrical | 3 | 03-06-2010 06:27 PM |
| LED lights | Animal | Electrical | 7 | 01-04-2008 06:06 PM |
| LED tail lights stay partically lit | cboy | Electrical | 20 | 07-21-2007 07:59 PM |
| Retrofitting LED bulbs? | Jag Daddy | Electrical | 4 | 09-08-2003 04:16 PM |
| LED conversion bulb question | HotRodF100 | Electrical | 3 | 06-21-2002 06:42 AM |
