The flasher manufacturer just want you to provide fuse protection for your flasher in the case that a wire gets grounded out or the load is higher than the flasher is rated for.
![]() Grote 44890 Grote states a min of 1 Amp fuse, a max of 20 Amp ... as stated on the flasher. ![]() Quote:
Using the formula: Amps = Watts/Volts Amps = 300/12 Amps = 25 So, if this flasher is capable of flashing 12 bulbs, (25/12) the 2 amps per incandesant bulb makes sense. LED's will draw significantly less, so IMO I'd start with a 5A fuse and go up from there if it blows. |
66GMC, There already was a fuse for the turn signals but I went ahead and put a fuse on the hot side of the flasher (it's a two-pronged unit, excluding the ground). I did that on the assumption that the flasher needed a fuse independent of the turn signals. Was I wrong>
The way to tell for sure is to test the flasher with both fuses installed. If it works, remove the one in the original location and see if it still works. |
| Custom LED tail ligths, how to bundle led's? | Augusto | Electrical | 3 | 03-03-2009 12:30 PM |
| Flasher Woes | grapro | Electrical | 3 | 08-01-2008 01:11 AM |
| Flasher Woes | grapro | Electrical | 2 | 05-06-2008 03:58 PM |
| Flasher noise all the time | hank medlock | Electrical | 4 | 12-27-2005 06:22 PM |
| turn signal blowing flasher fuse | RodFather | Electrical | 12 | 05-13-2005 06:23 PM |
