LED indicators - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-30-2007, 11:56 PM
wstory's Avatar
LED indicators
where can I buy small, like .25" dia., chrome trimed LED indicator lights for my instrument panel. I've hit several suppliers and found larger ones or smaller w/o the bright trim. Any leads appreciated.
Old 07-31-2007, 12:35 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
Have you tried a google search using your parameters?
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 07-31-2007, 05:58 AM
302 Z28's Avatar
You will have to search for them as these two companies have extensive online catalogs.
DigiKey
Mouser
Vince
Old 07-31-2007, 07:21 AM
Irelands child's Avatar
I can't find Doc's earlier post(3-4 mos ago), but don't you need to control voltage, ie, make sure that you limit it to the rated voltage - probably 12V and possibly add a diode? My taillights look like they are already set up that way. I'm going to be using some LED's in my dash and from the looks of them, they are just common aftermarket 12 volt pieces from Yogi's or Yearwood or similar hot rod supplier.
Dave
Old 07-31-2007, 07:59 AM
wstory's Avatar
Originally Posted by docvette
Doc here,
Doc
Tx, I'll try google
Old 07-31-2007, 09:13 AM
edge's Avatar
Time is short, are you ready?
Try your local Radioshack.
Ed
Old 07-31-2007, 09:14 AM
AllSteel34's Avatar
These guys have them along with a lot of other interesting electrical system parts.
http://www.americanautowire.com/
Chris
Old 07-31-2007, 09:25 AM
302 Z28's Avatar
If you go to a rodder specific supplier you are going to pay 5 to 10 times what an electronics supplier will want. Digikey, Mouser, and allied Electronics all have vast supplies of all kinds of LED's. They even have 12volt 1/4" panel mount with chrome bezels. I used them in the dash of my 34 and I paid about $2 to $3 each. Attached is a picture of but one style of panel mount LED with a chrome bezel.
Vince
Old 07-31-2007, 11:20 AM
Last journal entry: Bringing home the 401 Nailhead
Here are some at Summit
http://store.summitracing.com/egnsea...DS=1&N=700+115
Old 07-31-2007, 12:39 PM
wstory's Avatar
Tx, I'll try google
Thanks all! Now I got more sources than I know what to do with. Decisions!, decisions!
LED Turning Signal Problems Ted's37 Electrical 2 07-06-2007 12:36 AM
Auto body Led.... how well does it blend.... harrington Body - Exterior 3 05-08-2006 09:18 PM
Home made LED tail turn brake crownver Electrical 2 02-19-2006 06:46 PM
STop/tail Turn LED wiring chrisf Electrical 3 02-10-2005 08:13 PM
Auto Body led Dawger Body - Exterior 3 09-20-2003 12:30 AM
