LED Lights
Does anybody know why my LED lights flash when I honk the horn?
Doc here,
Check to be sure your not picking up power from the horn side of the horn relay.. Doc
Aftermarket Solutions Electronic & Electrical Innovations |
Doc here,
And...Do they work normal otherwise? or only when the horn is blown? Doc
They are in the dash, directional signal and high beam indicator.
They work normal otherwise, just light up when the horn button is pushed.
its not in the steering column because I eliminated that and it still does it. |
Doc here, Good call Denny! I was going to suggest the same thing! Try putting a 1N4001 Diode ($1.50 at rat shak for two) on the horn relay activate line..should be the small black wire. The Collapsing field on the relay could be inducing a forward Bias on the diodes as the relay opens and closes, causing them to "Blink", It only takes a small amount of voltage to light them off. Also be sure none of your wires cross that or other close circuits under the dash, give it as much separation as possible. Doc
| LED Tail Lights | Mako68 | Electrical | 9 | 11-06-2006 08:47 PM |
| HowTo- Led Instrument lights. 1? | 1Fast65Elky | Electrical | 6 | 08-14-2006 07:25 PM |
| LED tail lights, third brake lights ? | 1 Day | Electrical | 6 | 02-18-2006 06:33 PM |
| Added LED Brake Light,works only with lights off! Help! | TheBreeze | Electrical | 7 | 09-06-2005 10:58 AM |
| LED Tail lights | 49dream | Electrical | 4 | 03-24-2005 11:57 AM |
