The quick answer is if you use an electronic flasher it should work with any type of lights.
Artificial Intelligence is no match for Natural Stupidity Chet |
Flasher is all you need and sometimes you dont even need the load resistor with the regular flasher. Its trial an error and really depends on the LED lights themselves which some pull more current (although low) than others
But yes, if you put a digital flasher then you're all set, no resistor needed. |
It has been brought to my attention that some of these electronic flashers are wired backwards.
They will only work if the feed wire goes to the right terminal on the flasher. Might----and I emphasize MIGHT----have to pull the fusebox and swap the two wires in the flasher slot to make some electronic flashers work. |
You also need to put it into the turn flasher slot not the Haz flasher slot. Sometimes the electronic flasher doesn't work with stock wiring, that was my case till I re-wired the car. Anyways Superbrightleds.com carries everything you need, I'd buy the flasher and the load resisters and return them if you don't need them.
| accessory lights dim when head lights turned on | 36int | Electrical | 8 | 04-10-2011 11:59 AM |
| tail lights and dash lights quit | ashman | Electrical | 5 | 08-30-2010 12:27 AM |
| 79 TA: dash lights and tail lights fuse keeps blowing | Gladis | Electrical | 6 | 12-01-2007 12:43 AM |
| Parking lights from Turn signal lights | 32chevy vett | Electrical | 7 | 03-30-2007 06:46 AM |
| voltage to tail lights vs brake lights? | stratt134 | Electrical | 12 | 06-10-2006 06:51 PM |
