We're winning the case!
Hotrodders Bulletin Board > Tech Help > Electrical
  #1
Old 01-22-2003, 03:11 PM
zonk's Avatar
zonk zonk is offline
Home Built Rods No Rules
Smile LED tail light conversion
I've seen some of these LED tail light conversions,is there anything special in wiring these or just like any other light?
Old 01-22-2003, 04:50 PM
38ChevyCoupe 38ChevyCoupe is offline
Post
The only diff,. that I am aware of is that you will need a low resistance flasher
Old 01-23-2003, 04:57 AM
48Man's Avatar
48Man 48Man is offline
Post
I'm not sure of your application, but I'll you about mine. I drive a 48 chev with small tail lites and was worried about being seen. I tried the Led type bulbs(1157 type). They are brighter than stock 1157's but very directional. Meaning light straight out. I still wasn't satisifed, so I bought some halogen (1157 type) with 55 watts on the stop/turn side of the bulb. They are the best for me because they iluminate from the refelector out creating a larger brighter light. I hope you can make sense of this explanination. For my application I think I have the best for my application. I'm also considering a third rear window light. Hope this helps.
Old 01-23-2003, 05:47 AM
WoodsEdge's Avatar
WoodsEdge WoodsEdge is offline
Post
48man, thanks for the info. I've loked at both and didn't know which way to go. Do you know anything about the LED conversion kits? Are they brighter?
Jack
Old 01-23-2003, 06:38 AM
zonk's Avatar
Post
ALSO 48MAN DO THE HALOGEN BULBS HAVE A DECENT BULB LIFE I TRIED THE BRITE BULBS DIDN'T LAST HARDLY AT ALL? I KNOW THE LED ARE VERY BRITE BUT YOU HAVE TO HAVE THEM JUST RIGHT TO SEE
Old 01-23-2003, 09:32 AM
48Man's Avatar
Post
I'm not sure what you mean about conversion kits. My application didn't a kit. Please explain.
As far as the life goes, I drive my car every day with night driving too. It's a daily driver. I have been running the bulbs for about 6 months now.
Old 01-23-2003, 09:45 AM
zonk's Avatar
Post
something I seen in streetscene by Technostalgia Inc, I believe you use the same light just take out the bulb assembly put in this LED conversion and wire it back in. Just wondering if anyone has done this and how it worked out.
Old 01-23-2003, 09:54 AM
48Man's Avatar
Post
Are you talking about the front of the car or the back. What kind of application are you seeking?
Old 01-23-2003, 10:38 AM
zonk's Avatar
Post
I'm sorry conversions for your brake tail lights
Old 01-23-2003, 10:53 AM
pasadenahotrod pasadenahotrod is offline
Post
Here is the low-buck and simple solution to get better, brighter stop and turn lights, front or rear.
1. Remove the lens and bulb. SCrub the inside of the taillamp housing as cleanb as possible. Mask off the socket and surrounding sheet metal. Get a can of appliance gloss white paint from any Walmart. Spray the inside of the taillamp assembly nice and evenly. Let dry.
2. Instead of 1157 bulbs, use 2357 bulbs ( the stop/turn filament is much brighter than 1157). Install in your sockets.
3. Scrub the INSIDE of your taillamp lenses with soap/water and a toothbrush. If you do this in a washbowl you'll freak at how much dirt and gunch is on the inside of your lens. Dry 'em and install them.
4. Clean the outside, too.
5. Put on your sunglasses, especially if you're trying them for the first time at night! Don't want anyone being blinded!
Old 01-23-2003, 11:05 AM
48Man's Avatar
Post
All pasadenahotrod( I hope I spelled that right) is great and correct, except the halogen bulbs are brighter than the 2357's. I tried them too. The halogen bulbs that I'm referring to just plug into the original sockets.
Old 01-23-2003, 01:45 PM
Post
48man!
You are so right, but I was talking lo-buck! You got it right on the spelling. Do you really live in Tyer TX?
Hey that 36 looks goooood!
Old 01-23-2003, 02:50 PM
48Man's Avatar
Post
That 36 does looks real good, too bad it's not mine. I've got a 48 Chev Aero with a LT1. P/S, PDB, TILT, A/C, auto tranny,and Nova clip. I love my car but it's not pretty yet. I'm saving my $'s for a paint job. Thanks for the interest.
Jess
ps Instead of painting the inside of the tail lite housings white, I cleaned them and then lined them with chrome tape. So good so far!
Old 01-23-2003, 02:53 PM
48Man's Avatar
Post
I forget to reply, Yes I do live in Tyler. It's going to be 11 degrees here tonight, I've got my Aero all "tucked in".
Old 01-24-2003, 12:20 PM
bullheimer's Avatar
bullheimer bullheimer is offline
"al Qaida live in a Nebula"
Post
would advise you to put in 1A inline fuses because a higher fuse like the one in your fuse box wont protect your high dollar bulbies. the bulb you use should tell you the ampherage required on the package. fuse accordingly. but i've found i keep blowing fuses rated under one amp.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
