Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - LED tail light problem
Old 10-18-2012, 09:38 PM
sedanbob's Avatar
sedanbob sedanbob is offline
I had a similar problem with my front parking/turn signals - had LEDs front and back, and the correct flasher for LEDs. Both left and right worked when the lights were off, or just the parking lights on. When I turned on the headlights, left worked and right didn't - came on steady, no blink. I switched the lights left to right to check if it was the light or the wiring. The right now worked and the left didn't. The circuit within the LED was the problem. I got tired of fighting with it and swapped both front lights out for regular bulb fixtures - no more problem.
