LED tail lights, third brake lights ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2006, 09:38 AM
I'm looking at LED's for the hot rod. Does anyone know anything about Lambert Enterprises products? They have what I want, just curious if anyone has used thier stuff.
Old 02-18-2006, 11:44 AM
Frmly sc*ot.
Superbright LED's
Try this site.
I installed a few of their 5MM bright leds in my dash to indicate fuel pump on [blue] , TCC converter engaged [white], and cooling fan on [aqua green].
Even though I used the correct resistor [560 ohm], they are so bright there is no way I can drive down the road with the fuel pump on [blue] led blaring me in the face. I had to install a resistor 39X as much (22K ohm} to dim the led down to a reasonable level.
Old 02-18-2006, 04:00 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Scot:
Your URL wasn't Working, so I edited your post to fix it...In case your wondering what changed!
Doc
Moderator
Electrical Forum.
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 02-18-2006, 04:04 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
1DAY:
Here is the URL for Lambert's Website:
Lambert Enterprises
They make a pretty good product, There is some Construction plans on the site also..Worth a read.
Doc
Innovations
Old 02-18-2006, 04:13 PM
Frmly sc*ot.
Thanks, Doc
Old 02-18-2006, 04:16 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
No Sweat!
Doc
Innovations
Old 02-18-2006, 07:33 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
I used Lambert.
Tail lights are total custom design lens (by me) they (CNC machined). They built a special LED circuit board also.
Center-high brake light is a Lambert standard product.
Works great, looks great.
However, they couldn't make an enclosure for the circuit board.
They can make anything you want. You need to design it.
vicrod
Added LED Brake Light,works only with lights off! Help! TheBreeze Electrical 7 09-06-2005 11:58 AM
LED Tail lights 49dream Electrical 4 03-24-2005 12:57 PM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 07:17 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 04:34 PM
Wiring Tail Lights & Turn Signals horvath Electrical 15 04-30-2003 06:04 AM
