Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - LED tailight lense?
Old 03-25-2012, 01:31 PM
vicrod's Avatar
vicrod vicrod is offline
life is a ride
Last journal entry: 2014
If you want to retain the '56 chevy tail light lenses try to replace the bulb with an LED bulb. Should be much brighter. Use a red bulb. www.superbrightleds.com handles a good selection of LED products. Just make sure the LED will fit the old socket.
Clean the old lens to remove oxidation etc.
Replacement tailights (lenses) should be DOT approved. In some States non DOT lighting will not pass inspection. Check it out.
vicrod
