LED turning light resistors getting hot? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2012, 12:30 PM
staleg's Avatar
Last journal entry: Hand brake
I understand I have to use a resistor on the wires to my LED turning lights, and I have bought 4 pcs.
Do these get hot when used? I would like to strip them together with the wires, but can't do that if they gets hot during use.
Old 01-11-2012, 12:45 PM
35terraplane's Avatar
Led resistors
The resistors will get hot, they are a load on the system, that is what they should do. You don't need resistors if you use electronic flashers you need two one for signals, one for hazards. They work on most cars. I got mine from from Technostalgia. I have LED's all the way around plus third brake lite.
Bob
Old 01-11-2012, 12:50 PM
staleg's Avatar
Ok, thanks!
Old 01-11-2012, 03:41 PM
T-bucket23's Avatar
Wiki Edits: 26
What wattage resistors did you use.
I agree with the electronic flasher. They are a better solution
Chet
Old 01-12-2012, 06:32 AM
staleg's Avatar
I know an eletronic flasher may be a better solution, but I have a brand new wiring kit and don't want to mess too much with it.
And I have bought resistors at a local car parts store spesially intended for the purpose.
Old 01-12-2012, 07:18 AM
T-bucket23's Avatar
Wiki Edits: 26
You just unplug the old one and plug in the new one.
Chet
Old 01-12-2012, 09:24 AM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Maybe you installed too larger of a resistor? How many FPM are you getting?
A electronic flasher will take in account how many lights (LEDS) it has to flash and adjust the FPM.
Old 01-12-2012, 10:01 AM
staleg's Avatar
I have checked. It's 2 flasher relays on the fuse panel. They have 2 pins each. It's an Easy Wiring kit.
I see the 3 pin flasher relays are the most common?
Will any 2-pin flasher relay work for me?
Old 01-12-2012, 01:55 PM
T-bucket23's Avatar
Wiki Edits: 26
Any electronic flasher should work. If you have 2 one is probably for the emergency flashers.
Chet
Old 01-14-2012, 11:40 AM
staleg's Avatar
I won't use the resistors, as you recommended. The store where I bougth them, took them in return.
My car has 3 turning lights on each side. 1 normal bulb and 2 LED bulbs.
The guy at EZ-Wiring customer support told me I probably won't need electronic flasher relays or resistors at all.
I will put it together as it is. If the signals flash too fast, I change to electroic flasher relays later.
Thank's for your help!
Old 01-14-2012, 04:25 PM
EOD Guy's Avatar
You will probably only need one for the turn signals, if your's is like mine with the round slot...... I could only find the square elec flasher, so...... I made up a pair of short jumpers with male and female terminals..... plugged the male into the slots and the females onto the flasher, used a wire tie to secure it to the wires just above the fuse box..... works very well. I'd didn't need a separate flasher for the haz side...... don't know why, but it works as it should.
Tail Light Light-Bulb 65comet Electrical 13 09-28-2008 11:10 AM
My 74 swinger eats ballast resistors! 73 Nova Guy Electrical 7 12-09-2007 07:42 PM
Bad Stop light?(brake light) A-BodyFan Electrical 7 03-09-2006 03:19 PM
Turning off S10 "Service Engine Soon" Light. VonGooch Electrical 8 01-18-2004 09:56 AM
turning a 350 and 400 into a 383 and 377 bullheimer Engine 8 05-17-2003 04:43 AM
