left a block outside in the rain for a year - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2006, 12:28 PM
bullheimer's Avatar
NEVER use credit cards!
what do you think i will have to do to it now? it needed to be bored .030 over so i fiugred ***! did i screw up again???? i been told all the bearing surfaces will need to be gone over, ie line bored and maybe even taking the cylinders out to 060!
Old 06-11-2006, 12:45 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Bull,
Take it to a good machinist and have it checked out..Might be savable..Mains and cam bores will probably need to be honed at least..0.30 should clean the bores we hope..
A good boiling out and magnaflux check to see if it is good should be done anyway,,
Sam
Old 06-11-2006, 01:09 PM
BOBCRMAN@aol.com's Avatar
Biggest problem will be the bearing surfaces. If the block had cam bearings in it. You will be OK in that area. Check lifter bores for pitting and main bores will probably have to be honed. Cylinder bores MAY clean up at.040. Otherwise it will have to go bigger... You prob should consider using another block!
Old 06-11-2006, 02:05 PM
bullheimer's Avatar
hey bob, good to sse you around. didn't like what you had to say much tho. the bearings are all in it still, the lifters arn't. cant just thro it away as it was a virgin 400 block just don't have a place to put it, but shoulda wrapped it up. don't have a vehicle to put it in either. oh well. still sounds salvageable, just wont be able to sell it for the $300 i coulda got last year.
obviously, they must make lifters oversized?
Old 06-11-2006, 05:17 PM
Bull, I just saw a 400 block ,WITH NO MAIN CAPS, worn out .030 bore and cracks in the steam holes go for over $200.00 last week on Ebay!!!! Yours still gotta be worth $300.00
Good luck finding stocker type oversize lifters. It takes a lot to kill the lifter bores. Run a berry bush or brake cyl hone thru them, just enuff to remove rust. Then take a lifter and make sure it fits snugly and rotates..You will be surprised
Old 06-11-2006, 07:20 PM
bullheimer's Avatar
oh, i already am! but those high hopes are usually more than i expect. so you are saying good luck if my lifter bores are rusty? i will check it out some time in the future. i have a feeling, which is why i hung onto the block in the first place, that someday something will come along. and if it doesnt. i may end up building it stock to put in my pickup, as my 6000 lb truck seems to be a bit much for my 350. that's good news tho, thanks! i will bag that block after a good scrubbing and drying off with the proper grease all over everything. i was, in addition to boring it, planing on having to line bore it as well. i have a 455 for my pontiac, remember that?, that is first order of business, and even that is after 1-i get my truck painted (just spent over a grand on body work/windows and felt), and 2- i get lower gears for my pontiac. i presently have -i think anyway- 2.73:1 in it. but i will take better care of this 400 post haste.
Old 06-14-2006, 05:14 PM
Tazz
Don't they call that seasioning the block?
Unless the intake was off and the rain filled up th block it should be OK to take to a machinest and have him give it a look see. I have engine's saved in my garage a 350sbc, 406sbc, 377sbc, 305sbc and a truck load of parts...I don't want to sell them on e-bay and package them up and send them off....maybe I'll load them up and take them to a swap meet.
Tazz
Old 06-17-2006, 11:48 AM
King of my Man-cave.
It would be worth your while to seek a machine shop in your area that has a Sunnen (formerly Am-Pro) bake oven/shot blast cleaning system. Running your block through one of those will remove a lot of the rust. We have that kind of system and it works great.
tom
Old 06-18-2006, 01:55 PM
bullheimer's Avatar
i just bagged it tom. i'll worry about it when i get the $75 the shop down the street wants to clean and magnaflux it. i just got laid off friday. i'm not gonna spend a dime on it now. i even got the trash bag for free. i am putting the grill back in my truck today. tried yesterday but forgot i gotta attach it to the lower valance to get those bottom screws in. gotta beat the rain. i know, noon is a great time to try and beat anything!!!! if i build this thing it will probably be stock to put in my 4x4. it's a shame in a way, cause it would cost just as much to build stock as to build race, with my current heads that is. oh well, that's why it will be on the back back burner, unless my 350 blows up
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
Building A 302 Chevy Scorpio Shaping Flow Hotrodding Basics 6 01-16-2007 06:55 AM
SBC Block I.D. Casting# confusion 1Fast65Elky Engine 2 10-13-2004 08:44 PM
Late guts in an Early block??? jameskirk1 Engine 2 04-01-2004 01:59 PM
Block year preference mitmaks Engine 6 07-29-2003 06:41 PM
