Left on the road side a 3:00 am - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2002, 12:13 PM
Wink Left on the road side a 3:00 am
I "had" a 1979 TH400 out of a 1 Ton pickup in my 1979 monte. At 3 in the morning with out a sign of failing it simple stoped turning. I have a B&m Star shifter, had new fluid and filter and a new solinoid. does anyone have an idea why it would just up and crap out with out any signs of doing so?
hope so, 79monte
Old 02-28-2002, 04:10 PM
johnnymopar's Avatar
Love your nails! You must be a Libra
Question
What exactly happened to your car? Is this like a seized engine problem or electrical or what?
It could be any number of things, but need more info.
JB
"Well done is better than well said." - Benjamin Franklin (1706-1790)
Old 02-28-2002, 09:23 PM
Post
Nothing happened to the engine, or the electrical, my tranny stopped turning the ol' drive line, the car was coasting, but the engine kept right on going, I was currious how i lost the tranny. And if i may be resonsible. This all happened at 60 mph and about 2,000 RPM
Thanks
79monte
[ March 01, 2002: Message edited by: 79monte ]</p>
Old 02-28-2002, 09:24 PM
Post
Congrats to Canada, they diserved it
79monte
Old 03-01-2002, 06:24 PM
Thumbs up
thanks. believe me, all of Canada was celebrating that win. The last time Canada won gold was 50 years ago! They played a great game. The U.S. played well too, but i think after Nagano, '98, there was no way that Canada was going to come home without the gold.
JB
Old 03-02-2002, 02:18 AM
Post
is drive shaft turning I lost a rear end and tought it was the trany pin in spiders broke a loud bang a week earlyer was the pin braking it fell down in bottom of rear end it was 10 below and no other noise i tought somthing hit the under side of car bad guess i didnt check it out close enough good luck
Old 03-02-2002, 10:08 AM
Post
Rear end is fine, I'm curious, could the cable lincage being hooked up/ adjusted wrong fry my tranny? <img src="confused.gif" border="0">
Old 03-11-2002, 08:07 AM
Post
Need more info,but heres a few things to look for,bolts to torque fell out,front pump took a hike,forward drum broke at weld,even your shifter linkage in trany could have fell apart not allowing vale body to stay engauged,torque converter fins came apart or damaged,no turbine effect.
NOVA JEFF
Old 03-12-2002, 01:06 PM
Question
Ok, The tranny fluid was milky, and gray. Tranny still went into park, and other tan that I've told every thing else.
Thanks,
79monte
Old 03-13-2002, 04:54 AM
Post
If the trany fluid was milky looking ck your radiator if lines are hooked to it for cooling. It is possible there is a internal leak from radiator core into trans cooler core allowing the trans and anti freeze to mix Ck trans level for overfill,radiator for loss of coolant. If this is the case the radiator fix/replace,clean entire cooling system. As for the trans, most likely it will have to be torn apart and cleaned and may require overhaul kit.Flushing the systems is an option, but the stuff will be in trans filter,pan,convertor and doubt this wiil cure problem. To verify above problem , unhook lines at trans cooler/pressure test rad. look for coolant dripping from cooler core.Another is to have a sample analisis done on milky fluid to ck for contaminants in fluid.Let me know what you find after basic cks and will go from there.
NOVA JEFF
Old 03-13-2002, 01:09 PM
Post
Sorry, I forgot to mention that it has an external cooler, I was curious if i hooked up the lincage wrong or if the tranny simple failed. The milky fluid was due to the shavings.thanks
79monte <img src="confused.gif" border="0">
Old 03-15-2002, 06:41 AM
Post
Sounds like with the amount of shavings that you had in the pan that this trans was already excessivly worn. Changing the fluid, filter on a trans lot of debries in pan is only a gamble how long it will last. If you didn't drain fluid from conv. old and new fluid is usually not very compattable, end result trans failure. As for linkage the best way to set it up wright is to put trans ih a gear and then put shifter in same and see if they mate if not {column} Slide rod down at trans to adjust ck all gear selection to ensure engagement.{Floor cable} If cable doesn't line up possible can adjust if adj. is capable at shifter, if not may have to slightly modify bracket bolted at trans pan. NOTE shift cable may could be stretched from wear may need new if frayed. Hope this info may help in your delema, let me know.
NOVA JEFF
Old 03-18-2002, 09:37 PM
Post
Thanks novajeff, Thats what i needed to know. The cable was new, and the b&m shifter was too. It was adjusteble and probably only engadged about 7/8 of the way. Enough to pull hard and fail unexpectedly. And the old fluid like you said was also kinda bad, there was years of shavings on the pan. Probably shoukd have had it checked out. Oh well, Live and learn,
Thanks for the info,
79monte
