Leftover GTO engine parts, how much are they worth? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2011, 09:33 AM
adam83's Avatar
I have the choke coil, Part number 7028097, stamped 8097, and the 'vacuum tree' or thermostatic vacuum control (sensor) as I've seen it called, both off an original 1968 WT code 400 out of a 68 GTO. I've seen some NOS Pontiac choke coils on ebay selling for $150, and new replacements for $37, and I still haven't seen a pontiac 400 vacuum tree for sale (if that is what its even called.) The coil looks like it's in good condition with no rust but it is a little dirty. Same with the vacuum tower.
How much are these pieces worth?
Old 03-01-2011, 10:39 AM
chevelle_502's Avatar
Get out the ducktape...
Last journal entry: Front brakes
Wiki Edits: 5
Price is always dependent upon supply and demand. Slap 'em on ebay and see what happens if you dont like the result just be the highest bidder to keep 'em. Judging from other I believe youll fall inbetween the numbers you give.
Old 03-01-2011, 12:33 PM
adam83's Avatar
Ok, I will do that. Does anyone know the actual name for the vacuum tree?
Old 03-01-2011, 04:51 PM
Thumpin455's Avatar
Ask me about Ethanol
Last journal entry: 65 GTO
If I remember right its a thermal switch, it opens vacuum when the engine reaches a certain temp. No idea how much it is worth, I think I have 7 or 8 of them laying around here.
Old 03-01-2011, 05:35 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
X2 some good advice.
You could also put them in our classified section and put make offer.JMO
Cole
What are all these GM parts worth? RJs73camaro Hotrodders' Lounge 5 11-20-2009 01:19 PM
What are these parts worth? zipfactor General Rodding Tech 1 08-24-2008 06:11 PM
Leftover Parts!!!!!! 94gmc Transmission - Rearend 11 12-05-2006 04:50 PM
leftover 383? shortdog0001 Engine 4 03-23-2006 08:33 PM
Parts worth saving ?? Sean N Engine 6 01-02-2004 08:11 PM
