Leftover Parts!!!!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-03-2006, 12:44 PM
I just finished rebuilding the transmission in my 94 gmc sierra. It is a 4l60e and i really need help figuring out where these extra parts go. One of the parts is a V shaped spring that i have no idea where it came from except i think it was somewhere in the bottom with the valve body and the other is a round screen that is about 1 1/2 inches long. it gets smaller at the bottom (or what i think is the bottom) where the o ring is. Does anyone know where these parts go?
Please help and thanks in advance,
Jason
Old 12-03-2006, 06:36 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Jason
No need to beg, Plenty of assistance around this web site.
How can you have parts left over after a proper rebuild?
One item you describe is a thimble filter. Your 94 tranny would need two. Both in the case under the v-body and separator plate.... Front one keeps some trash out of the lock up solenoid , 2nd one is at the rear of the v-body area for the small lube spray hole for the rear of the out put shaft.
V shaped item? Not sure what you have there.
got a digital camera?
Old 12-03-2006, 06:42 PM
well there is only one filter in the new kit so i think i might have something else but what you are talking about makes sense.
Thanks
Jason
Old 12-03-2006, 06:56 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Thanks
Jason
early 4L60E had 4 filters in the valve body . 2 square / rectangle units on the separator plate......
2 round ones in the case. one near the lock up solenoid area. One at the rear area of the v-body where the govenor thimble filter would go in a NON "E" 4L60 .
Old 12-03-2006, 07:56 PM
airworld2's Avatar
4l60e
filter sounds like pump filter, fits in the stator and yes it has an o ring. the v shape piece sounds like it was installed in the pressure control solenoid filter to keep it from sucking together, Gil Younger shift kit has them maybe someone had installed shift kit before you started.
airworld2
Old 12-03-2006, 09:15 PM
Any chance the V shaped spring is the anti-clunk spring for the center support??
Can you give us any dimensions, even rough ones?
Old 12-03-2006, 09:33 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
hmmmmmmmmm, I wonder if he left that round pump filter screen out?
gonna be a problem if it was.
I forgot about the TG spring thingy....... could be it.
Old 12-03-2006, 10:42 PM
Sounds like the screen he is describing IS the pump thimble filter. BAD DEAL.
Omitting that screen will yield SIGNIFICANT pressure loss, ~2/3 pump volume also.
MI2600's Avatar
Member# 3287
Left over parts is a sign of efficiency.
Old 12-03-2006, 11:12 PM
BigDawgsEatFirst's Avatar
400SBC4Life
Amazing...
I just want to give you guys that work on automotive transmissions for a living a pat on the back.
I was amazed by the various small parts,clips,seals, planets,sun gears,springs,solenoid's and valves that allow these transmissions to transmit power.
And that is not to mention the tasks of correctly troubleshooting the customers trannys.
Old 12-03-2006, 11:31 PM
thank yoo to everybody who helped me figure out what these pieces are and where they go. Yes there has been a shift kit installed before and the filter was to the pump. good thing i havent installed the tranny yet.This forum is a great place for everything. i think i will be here more often.
Thanks again
Jason
Old 12-05-2006, 05:50 PM
well i thought i had everything under control when i couldnt figure out where to put the pump thimble filter. someone said it fits in the stator. anyone know any details of where exactly. i thought it may fit in the pump but it doesnt so any help is good.
Thanks
Jason
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 04:07 AM
Prepping urethane bumpers and fiberglass parts? starquest Body - Exterior 19 12-21-2007 10:54 AM
2.3L parts cant seem to find any performance parts for it JustinHebel Engine 3 02-26-2006 12:49 AM
Hi, I am new!...I have asst. car parts.... SBelk2003 Introduce Yourself 3 01-27-2006 07:04 PM
1964 Muncie M-20 parts question 1964 Oldsmobile 442 Transmission - Rearend 3 04-10-2004 10:25 PM
