Length of Driveshaft - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-14-2008, 09:33 AM
71haulnazz's Avatar
Does anybody know how long of a drive shaft I need for a 1971 chevelle with a 350, turbo 400, and stock rearend??? The few local shops in Buffalo want $100+ to cut. But the real kicker is they cant cut bottleneck drive shafts!!!! I guess they are real hard to re-yolk?!?! But just wondering if anybody has done this I was going to p/u one at a scrap yard and go from there.
Old 10-14-2008, 09:57 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
http://www.dennysdriveshaft.com/how_to_measure.html
Old 10-14-2008, 10:10 AM
prostreet6t9's Avatar
Differential/Driveline
It is a problem to shorten those if you end up getting into the larger part of the tube,How much does the shaft need to be shortened? can you take a little off both ends and get the length you want? $100.00 to cut and balance don't seem to far out of line,so if they can cut both ends and get the right length,charge you another 30 or 40,it might be a little cheaper than buying another shaft at a bone yard and having to still get it worked on.
I believe the length you need is 55 1/2 center to center.
Old 10-14-2008, 01:41 PM
skeeveman's Avatar
I am the Antirice
My 71 Chevelle used a 55.5" Center to Center driveshaft with the TH350. With the TH400 that is currently in it, I'm using a 54.5" shaft.
Driveshaft length mightycarlo10 Transmission - Rearend 1 12-29-2007 11:41 AM
proper driveshaft length murrsue Transmission - Rearend 3 10-09-2006 12:03 PM
wrong driveshaft length? darom Transmission - Rearend 16 03-23-2004 07:59 PM
TH400 Driveshaft length mark2002 Transmission - Rearend 4 11-22-2003 08:46 AM
Nova Driveshaft Length 68NovaSS Transmission - Rearend 2 01-20-2003 09:19 PM
