lengths
Anybody know how long a small block chevy and a Turbo 350 each are? Together or separately, i need some numbers.
Turbo-350's come in different lengths. Here's a chart: http://tciauto.com/tech_info/trans_dims.htm
http://www.paceparts.com/index.asp?P...=Custom&ID=586 has engine dimensions, although http://www.carnut.com/specs/engdim.html shows different numbers. Last edited by jimfulco; 10-22-2005 at 12:07 AM. |
Thank you.
Thank you both for your help. that info will help.
And the powertrain is going into a '66 Dart, by the way... backwards. I've cut the rear seat area and trunk floor out and have welded up a new rear subframe, kinda like a '60's style altered wheelbase funny car. I'll mount the engine as far back as possible, with the trans. and transfer case facing the front of the car. I'll use the front axle drive yoke on the transfer case to drive the rear end (thru a VERY short driveshaft). A few hard coolant lines, new fuel lines, and a Moon tank, and it should be doin' wheelies in no time. I'll post pictures when it's done. |
...I haven't worked thru the rotations of all those parts yet, though. Wonder if i'll have to flip the rear end end-for-end to get it to move in the right direction in Drive.
| Recent General Rodding Tech posts with photos |
| Chevy v.s GMC truck A-arm lengths? | Gearhead forever | Suspension - Brakes - Steering | 6 | 09-10-2004 11:15 AM |
| spark plug wire lengths | robman909090 | Engine | 8 | 05-12-2004 10:07 AM |
| Quick dumb question on air hoses and lengths | unstable | Body - Exterior | 3 | 12-31-2003 03:07 PM |
| 9" Axle Lengths | 68NovaSS | Transmission - Rearend | 5 | 02-08-2003 09:00 AM |
| pushrod lengths | blown 34 | Engine | 2 | 01-19-2003 10:24 AM |
