Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Less mpg on premium vs regular
Old 12-06-2012, 05:35 AM
bondo's Avatar
bondo bondo is offline
Originally Posted by ogre View Post
premium gas has more anti knock stuff in it so you can run higher compression engines with more timing
your best fuel will be the lowest grade you can run
Ayuh,.... Exactly,....
Premium is a Waste of money, unless yer motor Needs the less volatile fuel...
