Less mpg on premium vs regular - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-05-2012, 07:31 PM
mitmaks's Avatar
Last journal entry: Grille
So I filled up my car with premium and some injector cleaner. I got less mpg than I get with regular. I would think I'd get more mpg with premium.
Any thoughts?
Old 12-05-2012, 07:41 PM
tnovot's Avatar
I wouldn't think it would make any noticeable difference. Unless you have a controlled test using differennt octanes several times to get repeatable results, the difference you experienced could be due to whether or not the tank was filled to the same level in each case.
And maybe the fuel cleaner somehow affected the mileage?
Terry
Old 12-05-2012, 07:44 PM
mitmaks's Avatar
I do log my mpg. I hand calculate mpg every fill-up.
Old 12-05-2012, 07:53 PM
tnovot's Avatar
Then I'd do a few more tests with premium w/o fuel cleaner so see what happens. Other variables could be differrences in alcohol content (the gas - not you), more stop and go driving, harder accelerations, etc.
Terry
Old 12-05-2012, 08:17 PM
ogre's Avatar
the 'Duracell Project'
premium gas has more anti knock stuff in it so you can run higher compression engines with more timing
your best fuel will be the lowest grade you can run
Old 12-05-2012, 08:29 PM
sedanbob's Avatar
Premium burns slower than regular - without timing changes the potential benefit is probably being wasted out the exhaust. Ogre has it right.
Old 12-06-2012, 05:35 AM
bondo's Avatar
Ayuh,.... Exactly,....
Premium is a Waste of money, unless yer motor Needs the less volatile fuel...
Old 12-06-2012, 03:11 PM
Here is the answer on a thread at ecomodder.com Regular vs. Premium - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com
As mentioned here, there is going to be no better without a change in timing, and at that marginal.
Check out that forum guys if you want to help your fuel costs. I was blown away at what I learned. Those guys are as good at fuel milage Hotrodders.com is at making hot rods. Believe it, they know MUCH more about that stuff than you can ever imagine!
Old 12-11-2012, 12:11 PM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
High octane burns colder and needs more compression or timing to fully burn. You'll see higher emissions with that combo too.
Timing is a crutch in this situation. If your cylinder head/piston combo require 36* for regular unleaded to get a clean burn, adding 2 degrees for Premium wont yield ANY additional hp. Match, at best. You didnt change any cylinder pressures with the different fuel. You just lowered combustion temperature.
Old 12-12-2012, 05:17 PM
I do marginally better with 93 over 89 in my tbi pup but it's not worth the extra money. It's around 14.25 vs 13.5 mpg.
Premium Premium Introduce Yourself 3 04-29-2010 09:55 AM
Quantum Premium Filler Scode68 Body - Exterior 1 04-20-2009 07:12 PM
Mixing race gas with premium unleaded gto67ron Engine 11 11-07-2004 06:49 PM
Premium Gasoline? smallz Engine 4 08-02-2003 07:31 PM
highest compression on premium nd500 Engine 15 04-02-2003 12:10 PM
