Less wiring from alternator please... - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2004, 08:59 PM
BillyJoe's Avatar
Hi, I'm in the process of wiring my car and have decided to use a small GM alternator out of a 90's Cavalier, besides the main post to the starter there is a plug containing 3 wires, brown going to the idiot light(charge indicator), a brown w/white stripe going to the heater/AC fuse and red 10 gauge wire that joins the red wirie from the main post after it goes thru a fusible link. My question is...can I ditch the brown/white wire altogether, put a resistor on the brown wire which ran to idiot light and can I run the red wire right to the main post. I don't want all the wiring showing. Anyone?
Old 11-10-2004, 09:36 PM
cletis's Avatar
You can leave off the idiot light wire if you don't want a light. The brown/white wire is the regulator sensing wire and is needed. Yes you can run the red wire to the main post without a fusible link.
Old 11-10-2004, 09:51 PM
BillyJoe's Avatar
My schematic shows that the brown/white wire goes to the heater/AC fuse of the fuse block which is HOT IN RUN, I'm not running heater or AC, where can I connect it then??
Oh, do I connect it to the ignition switch at the 'run' post?
Old 11-10-2004, 09:55 PM
cletis's Avatar
The best place is to whatever accessory that is drawing the most from the system. If you aren't running any accessories the ignition post would probably work.
Old 11-10-2004, 10:34 PM
BillyJoe's Avatar
Great, thanks for the help.
