lesson learnd - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2002, 10:41 AM
Post lesson learnd
i put a carb spacer on my edelbrock intake the carb bolts werent long enough so i went to my local home depot and got four bolts not knowing the strength of theses bolts just bought cheepys .so when i put these ****y bolts in one snaped off flush with my intake whith very little torq now whats the simple way of getting this bolt out without messing up my intake??
Old 10-18-2002, 10:44 AM
1meancuda's Avatar
At a loss for words
Post
You could try something like the Craftsman Screw-Out thing that they are always advertising.....
Old 10-18-2002, 11:13 AM
cuda66's Avatar
Post
the tool you are looking for is an easy out. man I feel sorry for you. Be carefull or remove the intake. When you use one of these tools you first have to drill a hole in the bolt that you were using and there will be alot of metal shavings all over the place. have fun <img src="graemlins/crash.gif" border="0" alt="[crash]" />
Old 10-18-2002, 12:08 PM
Post
Here's the easy way.....tape over the intake opening. Use a drimmel to cut a groove in the bolt shank. Use a flat head screwdriver to back it out.
