let me ask a powerglide question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2010, 09:08 PM
I have a powerglide and some one told me if i kick up
the psi on it that it would give me more torck.
Do i just change the valve body?
I don't really know alot about trans.
I tryed to use a 2 inch spacer it really helped.(on carb 4 hole straight)
Does anybody know any secrets to get more torck with out
spending a grip of cash.
dumb question huh.
Old 03-01-2010, 10:12 PM
junior stocker's Avatar
You can use a "shift kit" to increase the line pressure PSI. But,that won't help you looking for more "torque". You can use a higher stall torque converter to get the engine RPM up into an area closer to it's "power band". For a cheap converter, you can use a Vega Powerglide converter, they're about $100.00 rebuilt. Otherwise, you're looking at a specialty converter. Butch/junior stocker.
Old 03-01-2010, 10:15 PM
right now i have a 2800 to 3200 stall (boss hog)
thanks
Old 03-02-2010, 08:36 AM
sqzbox's Avatar
My pipes are my music
Do you have headers?
How about more info on your engine and the car it's in? For all we know, you might be working on a 6 banger with a 4 bbl intake.
The ONLY dumb question I ever heard is "how did you get pregnant"?
Old 03-02-2010, 10:24 AM
Then, you need lower rear end mears. What kind of vehicle? Weight is going to have a lot to do with it too.
Old 03-02-2010, 08:26 PM
63 pannel van
468
373 posi
super street carb 830 cfm
headers
weight 3160
Old 03-02-2010, 11:56 PM
sqzbox's Avatar
What kind of cam? Stock, or HP? Your van weighs about as much as a third gen. firebird or camaro. That's pretty light for a van. The torque conver sounds like a good option.
Old 03-03-2010, 02:37 PM
You're kinda at the "iffen"weight for a Glide. If it were me, I'd go with a TH400. The van's a brick, big motor; throw some 4.56's and a TH400 in it.
Old 03-03-2010, 09:15 PM
the cam is elgin pro stock
sae dur :294 .50 dur 255 int. 263 exh. lift .555 to .551 (valve)
i have a 2800 to 3200 stall (boss hog) small
373 rear gears if i put 4.56 how will it ride on highway?
the th400 is what im leaning towards instead of the glide, does the glide
with stock gear not for under 530 horsepower and heavy vans
yah making a big beast hot rod
383 stroker 73monte Engine 13 05-11-2016 11:17 AM
supercharger.... 73monte Engine 16 07-24-2010 10:27 AM
2 speed powerglide trans 64r1 Transmission - Rearend 2 08-03-2007 10:29 AM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 01:20 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 10:25 AM
