Are you 100% sure that it is a 350?
Well, I know, but easier said than done in an S10. If this turns out to be the case I will need about 50cc chambers to get what I need. |
If it does not have deep dish pistons, you are really screwed.
You could have a 305, and not a 350 block, crank, and rods.
Thats what I'm saying. Even if it does have dished pistons I'm screwed. I just wanted to do the upper end and a good cam. But I cant if it's already a low compression motor with 58cc heads.
cubes and cr ?
Now I no guru, but It looks to me like someone could fizzer how to with the piston to the top, remove a plug and put something into the cyl. that wouldn't seep passed the rings to measure the volume and could be removed without harming the engine. Maybe even a balloon installed into the cyl. and measure the volume required to fill it.
With the piston on top, and the valves closed, measure the vol., subtract the head cc's should give you close to the CI. Maybe I wrong with different CI's, pistons (concaved, flat top and domed. It maybe to hard to tell the difference even having the block casing and head numbers. Anybody got a suggestion. |
The VIN might still be visable on the pad immediatly in front of the passinger side head if the rebuild shop didn't take a mill cut on the decks. Bogie |
Thats what I had planned when I get home tonight. I'll check the VIN pad first. That should at least tell me what it came out of etc. I find it very strange that this would come from a parts store. Maybe the guy lied to me. |
| how to run heat riser tubes? | matt167 | Engine | 1 | 09-12-2006 05:49 PM |
| Painless Electrical in 1959 Chevy Apache | Craig legacy | Electrical | 7 | 06-24-2006 12:36 PM |
| man, no matter how fast you are ya just cant outrun a radio! | RANGER_MIK | Hotrodders' Lounge | 37 | 12-06-2003 08:45 AM |
| 200 photos from Temecula Rod Run 2003 | xl1ken | Hotrodders' Lounge | 5 | 02-20-2003 06:15 PM |
