Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Let's discuss Dynamat alternatives.
Old 05-27-2012, 04:39 PM
hp246's Avatar
hp246 hp246 is offline
Originally Posted by DanTwoLakes
@hp 246: Yes, it works great on duct work.
I think the problem with most sound deadeners/heat shield/ insulation products is that everybody tries to cover every square inch with it. Anything will work to some degree. I just got some stuff called trunk liner that is about 1/8" thick and has a peel and stick backing on one side and a fuzzy surface on the other. It's only 10" wide, but I'll bet it would do a good job of insulating and noise reduction. It sticks like crazy, and it was really cheap. Here's a picture:
Dan,
I am most interested. In heat disapation from the long tube headers that run under the floor boards. I am referring to the butyl foil backed insulation available for heat at the local hardware. I know it is not the same as dynamic mat wonder if anyone has tried it.
