if its spitting out of the carb sounds like you don't have the dist installed correctly. pop off the drivers side valve cover and install the dist with the rotor pointing at cyl #1, the balancer at the TDC marks, and both the intake and exhaust valves closed. |
Sound's like your valve's need to be reset.
Hi,
You need to get the valves & compression straightened out, cranking press should be around 150# w/no more then a 10% difference between cylinders, when you look at the adjusting nuts on the rockers, are there about the same amount of threads showing on each stud?did you prime the engine? if you push on the rocker on the push-rod end, is it firm or can you push it down a little? As for the dist. I think your saying you can't move the dist one tooth because of interference with something, well lift the dist all the way out & use a long screwdriver to move the oil pump so the dist can go all the way back down , you may need to do this a couple of times, but I don't think this is your problem, at this time Good luck, Rich |
Something isn't right based on compression you give. Hotter cams are less tolerant of set up than mild cams for example. Cam could be installed out of time. Proper SBC installation for chain and gear cam drive is cam gear notch in the 6 position crank gear notch at the 12. Then after all other assembly and just before closing the timing case cover rotate the crank so the timing marks are all in the 12 o'clock position. It's now ready to fire number one. Now don't mess with it till the distributor is dropped in. You will need a long screw driver to position the the oil pump drive slot so the distributor shaft tang will align with the pump drive when the distributor is installed. If the dist. won't drop in, you've got to fiddle the oil pump drive till it does. It's real smart to do this when the engine is still on the build stand, even if you have to pull the distributor back off for installation, as once it's it all you've got to do is drop the dist. eliminating trying to feel it's way in when you can't even see back there to do it. Bogie |
The first thing you need to do is to get somebody over there that knows what they're doing or you are likely to do serios damage to your new motor.
Well I have the 120 to 125 in each cyl. with the rockers adjusted. I brought 1 Cyl to the compresion and placed the Dist with rotor at 1 I got an almost. the clostest I got, I got a backfire through the carb.
I am sure I lined up the timing gear but I cannot 100% guarantee I did. I have been trying to fire it up for the first time and just can’t get it. I am lining cyl. 1 at what I believe to be TDC lining the rotor up to wire 1 and just won’t fire. The next thing I was thinking about doing is pulling the front off and double checking the timing line up.
Check the firing order on the wires one more time.
Make sure the rotor isn't on backwards. Make sure the pin holding the dist. gear to the shaft isn't broken allowing the thing to slip around. If it is, find out why it broke before moving on. Bring the engine around to TDC using the balancer, as indicated with your timing mark. Check your #1 valves to confirm both are closed. If not, your balancer is wrong,(slipped elastomer ring, although unlikely it can happen) your valves are out of adjustment, or your timing gears are improperly installed. Get a second set of eyes over there. Go through the motions, plug wires, static timing, etc. Still no start? I'd pull the water pump and timing cover. Confirm the timing marks on the gears are where they need to be; if so take a look at where you have the dist. set. If not, reset (backing the valves off may be necessary to do this.) Reinstall the gears, re set the valves, bring it to TDC on the balancer. Mark your dist. cap for #1 with a sharpie. Put some oil on the dist. gear. Slide the dist. in , make sure it all lines up. Check your work. Try it again. |
Sounds to me like he just doesn't know how to set the distributor.
Again, save yourself a bunch of work, aggravation and money by getting someone there, or taking to someone, that knows what they're doing.
It's not that i wouldn't love to help you, but these types of things are often very hard to diagnose without laying hands on the subject. |
cant start sbc......
the whole problem is that he turned the carb 180 degrees.....i didnt know you could do such a thing.....
| possible 350 block purchase - comments please | idrva55 | Engine | 17 | 12-09-2007 09:29 PM |
| 350 running bad?flat spot in the rpm | J3Jon | Engine | 15 | 04-21-2007 10:45 AM |
| need a cheap running 350 | doughboy4265 | Introduce Yourself | 1 | 03-14-2007 06:58 PM |
| Extremely Hot Running 350 Crate Motor. Possible Reasons??? | ripvanhalen | Engine | 9 | 06-09-2004 07:06 PM |
| Poor running 350 | BrackneyC | Engine | 5 | 12-30-2002 11:48 AM |
