Jaguar Independent rear suspension comes with all the disks and calipers and everything just find one that been in accident are something you can find them for like $500 If you look hard then take the rest of car to scrap for $50-$100 depends on scrap value. Just an Idea
-Dirtdog |
yea I pulled a jaguar suspension out of my 74 XJ12L its sittin in the garage lol
I thought about it but in the long run im going to go with the C4 corvette dana 44 irs i hit a curb in my jag and got 3,300 from insurance took the rear irs out and towed it to a wrecking yard and got 550 bucks for the car. pretty sweet deal lol Im just looking for something simple to run until the money comes for vette irs this is my rookie project so just trying to figure out what a simple setup would be for the rear in the mean time. what are my options of mounting a straight axle? like as far as pinon supports, or 4 link setup or coil overs |
well If your not going permanent I'd just go with leaf springs way easier and cheaper then a 4-link alot less work to but the 4-link is way cooler then leaf springs you could also do a 2 link setup with coil overs or do triangulated 4 link so you won't need a pan-hard but there's lots of options to choose from just how much work do u wanna do just to cut back out basically maybe try finding a vette thats been in the accident for cheap and use the IRS you could probably almost get your money back after taking it to scrap if you got that much for a jaguar, corvettes are fiberglass so maybe not but why do the work twice and it cost way more to put the 4-link in and cut it out then put the IRS in way less labour to. Its up to you how much money you wanna waste basicly
-Dirtdog |
yea I should listened to my grandpa when he said those old cars are money pits ! I guess what im leaning towards is getting a cheap 10 bolt or 12 bolt off craigslist and getting a dropped leafspring kit
gotta figure out if i need to c notch the frame the front it pretty low ! |
yah I got a 48 merc (ford) pickup with mustang IFS in the front and just leafs in the back and it just clears a speed bumb in the front the back has an inch or 2 more clearance but I was told 3 inches is anough travel for the rear suspension travel if u have less then that you'll have to c notch it and just how low do wanna go if you go to low you won't even be able to go mcdonalds are anything inless you get airbags which is even more money lol Don't louse hope eventually you'll see why you spend all that money once your driving it down the road
-Dirtdog |
There are a few cheap disk brake swaps that you can do from the junkyard.
Assuming you are going with the 5 on 5 pattern in the rear you can use Impala rear rotors(around 1996) and 4th gen Camaro calipers. also Jeep Grand Cheorokees went to the 5 on 5 pattern around 2001 IIRC Shane |
| 61 chevy 1/2 ton rear axle | goneinsixty | Transmission - Rearend | 1 | 02-18-2009 08:57 PM |
| rear axle hop | bob schildt | Suspension - Brakes - Steering | 1 | 11-13-2007 02:34 PM |
| Chevy Truck Rear Axle Width | Tribal | Transmission - Rearend | 9 | 01-30-2007 09:35 PM |
| Suggestions for a rear axle | dpjim2 | Transmission - Rearend | 2 | 12-24-2005 11:04 AM |
| 1956 Oldsmobile Rear Axle | Ted's37 | Transmission - Rearend | 7 | 04-17-2004 08:28 PM |
